Ok so long story short my passenger side bulb on 90 JDM Z broke and it was an H3c bulb. I cant find these bulbs anywhere except for ebay or something so I used a regular H3 bulb and wired a second connector off of it. I knew this would work because the drivers side bulb was modified the same way. The only problem is the bulb is quite dim. It is only the passenger side bulb though, the drivers side is bright. Both are 55w H3 bulbs. Why is this? When i had the H3c bulb in the passenger side it was the bright. Also my passenger side high beam isnt working now. I know the bulb isnt burnt out because when i turn my lights on they are slightly lit. Any help would be great, thanks.
